any hint.!?
y-depth
craft
Re: y-depth
Hi Farhaad. yes, i think this will do what you want... import this material library to your scene and apply the material as an override to your pass.
Play around with the values in the "change_range" node:
-the old range represents the minimum and maximum height in your scene
-the new range represents how that will translate into color.
Right now its using 0 and 10 as min and max heights, translating into a full black to full white gradient. Anything outside those boundaries will be clamped to black or white, accordingly.
Tiago Beijoco
http://www.craft.host56.com
farhaad_yousefi
- Yahoo Messenger: farhaad_yousefi@yahoo.com
Re: y-depth
craft wrote:Hi Farhaad. yes, i think this will do what you want... import this material library to your scene and apply the material as an override to your pass.
i've imported the .xsi into view port but nothing happens and no shader adds into shaders list..
craft
Re: y-depth
yup.
see the picture:
Tiago Beijoco
farhaad_yousefi
Re: y-depth
but it seems the vector state on intersection points doesn't give the right position of each point in the scene.!! or something i've missed.!?
coz..it's ramp is not world dependence ..ant it moves with object.! thanks again for the effort.!!
craft
Re: y-depth
ooh no you didn't do anything wrong and neither did i!
XSI changed, that's what. i created that material in xsi 6.5 and it worked fine. now i just tried it under softimage 2010 and it didn't behave as expected. the "Vector 2 Scalar" node changed, so now what you need instead is the "vector to scalars" and link the output Y to the change range node.
i attached the Softimage 2010 material, but i don't know what version you're using, so it might not work on your scene...
Tiago Beijoco
farhaad_yousefi
Re: y-depth
aaaawesome.!!! thanks..man.!!
.tell me if i can help you in any of the following categories.!!
camera-tracking . modeling . compositing in nuke after effect . animating characters . rotoscoping .rigging. ... (anything but scripting ;) )
craft
Re: y-depth
hehe you're welcome mate. actually, i think i have an idea...
Tiago Beijoco
farhaad_yousefi
Re: y-depth
yes.!? what is it.!craft wrote:hehe you're welcome mate. actually, i think i have an idea...
