Select every nth edge
Eugen
Post by Eugen » 28 Oct 2013, 08:16
Hello,
what's the trick to select every, say, second edge of an edge loop (on a cylinder with almost 100 subdivisions)?
rcTools seem to be able to do this with polygons only...
Eugen
julius
Re: Select every nth edge
Post by julius » 28 Oct 2013, 08:28
what do you mean by "second edges" ?
Eugen
Post by Eugen » 28 Oct 2013, 08:38
Something like this...
Select patterns of components (points, edges, polys...)
Re: HeSelect every nth edge
Post by rray » 28 Oct 2013, 09:31
Hello Eugen! This should be possible by using the "complete all edgerings" command inside the more options submenu, and the "X_X_X_" pattern selected
Eugen
Post by Eugen » 28 Oct 2013, 09:39
Aha...! That works... thank you!
Bit tricky to find... I expected the "Apply Pattern to Selection" command in the "Loop Patterns" menu to do exactly this.
Post by rray » 28 Oct 2013, 10:08
I see-- I couldn't get this function to work in combination with edge rings. It's a bit difficult to make it clear from the UI perspective, am open for suggestions!
ndrakey
Skype: ndrakey
Post by ndrakey » 31 Oct 2013, 19:42
Grüß Gott.
I'd like to know how this "trick" works too :>
