indent is messed up
clankill3r
indent is messed up
Post by clankill3r » 05 Oct 2013, 09:48
My indents are broken.
Look at the screenshot, i have to place it like that to make the script work (look at the line 22, 23, 24).
If i copy paste my script to a text editor then my indent's are as expected.
Do more people have this problem (bug)?
I'm using si2014 sp2
Re: indent is messed up
Post by EricTRocks » 05 Oct 2013, 12:24
You should turn on whitespace in the script editor preferences to see if all the indentation is consistent. Sometimes you get tabs and spaces mixed in and can cause issues.
One tip, select all the text, hit tab, then hit shift+tab. See if that helps.
Eric Thivierge
