Hello,
I want to know How can I assign -N- Orientations of a Group of -N- Nulls to -N-number of Particles, so the number of null is equal to the number of particles
I know I can get each null separatly and do a get kine.global.euler + kine.global.pos for each null an plug it to an add point, works perfectly...but that's one add point for each null and over 100 or more it's a little pain to set it or change it,a script could do an automatic job on wirting it, but I recently I find out I could make a group and get the kine.global.pos and assign to just ONE add point node and generate all the particles , it work fine for positions, and if I removed or add a null from the group it updates rigth away, but when is time to set the orientation I can only put one value on the set orientation node....sooo how can I assign the specific null orientation to the specific particle pos on the same add point node? or I'm just taking a dead road and should go back to one to one pos/euler assignment from each null?
is there a work around or something? I would really want to maintain the Group workflow if possible.
I attach a pic of the tree and the instanced models(the chairs)..it's very simple
bye!
Assign orientation from Null Group to particles
jmquintela
- Skype: jm_quintela
caledonian_tartan
Re: Assign orientation from Null Group to particles
try this.
the add node is just to give a 90° offset, so that the particle cones point in the same directions as with the null arrows.
SI 2015 @ WIN7-64
jmquintela
Thanks!, work perfectly!.
jmquintela
Building in this same Question,
If I Want to assign different models to different Nulls , How I should Use - Find in array - to filter different groups and use different instances models , So I can .
I attach the compound ... it's not working properly I don't know what I'm doing wrong... you have to connect three null groups to make it start on the modling ice tree, very simple.
Bye
Bye
jmquintela
This is a JPG of the tree
