Polygon Display Option like in pointcloud?
Contac
Hey Guys gives à Way to Display high dense poly meshes As Box or Disk like in pointcloud Display options in ICE ? Can i Setting à mesh in ICE with pointcloud to Box or Disk? greetings Contac
dwigfor
Re: Polygon Display Option like in pointcloud?
You can set object's Display to Bounding Box. Open explorer, under display (make local), set Bounding Box apply all. Next, in viewport you have to uncheck first item - Overide something.
That also is useful for forcing objects to display as wireframe tho your viewport is set to shaded or whatever.
- Skype: ondraise
Handy tip, thanks. =)
julca
At work we massively use this method to display 2d plans, or special objects, through groups with this "Display" property (but of course in "texture decal" mode instead "bouding box" here).
Groups allow us to quickly switch many objects at once.
