get fisheye shader to work
clankill3r
Post by clankill3r » 11 Sep 2013, 20:41
I have readed so much documentation. Maybe i skipped something but i can't get it done.
How can i get the lens shader fisheye to work?
What i do:
1) create a new scene
2) set mental ray as the renderer (my default is redshift and there i can't get it to work neither)
3) open render tree
4) select the camera in the explorer
5) right mouse on the lens shader
6) 'add item'
7) drop a fisheye shader
8) connect it to the lens shader
9) open fisheye ppg
10) set distortion to 1
11) set scale to 10
12) draw a render region
13) yell at my pc
14) try again starting at step 1
I also tried it as a pass shader at the default_pass but this had no effect.
amm i missing a step?
Re: get fisheye shader to work
Post by NNois » 13 Sep 2013, 08:04
hi,
Scale at 10 ??? obviously it's the problem
here a screenshoot and repro steps:
- default scene
- add a cube
- select the camera
- open the render tree
- right clic lens shaders "add item"
- connect fisheye Distortion&Scale default 1 / 1
- draw a render region
clankill3r
Post by clankill3r » 13 Sep 2013, 09:56
I did scale at 10 cause i had no result.
I did your steps and again no result. What are the values you use?
Could you upload your scene?
Post by xsisupport » 13 Sep 2013, 10:07
All you need is a cube and the default shader settings.
But if you're zoomed out too far it may appear that nothing is happening.
// Steve Blair
clankill3r
Post by clankill3r » 13 Sep 2013, 11:03
It's the render i use. If i switch to mental ray the fisheye works again.
