Deforming geometry with particles?
noodleman
Post by noodleman » 10 Sep 2013, 20:15
Hi, I'd like to create an effect similar to that of Paul Smith's in his "Jiggly Bit" video (see below), but instead of an object being deformed by a "prodding" geometry, I'd like to use emitted particles (with instanced shapes) to deform the object.
Here's the ICE tree for Paul Smith's effect (it's attached as a simulated ICE tree to the object being deformed):
And the video:
What's confusing me is with what I ought to replace the "Get Closed Location on Geometry" node, since I assume some new logic is required when trying to interact with particles.
Re: Deforming geometry with particles?
Post by Bullit » 11 Sep 2013, 06:27
Wouldn't these ones be better?
noodleman
Post by noodleman » 11 Sep 2013, 10:24
Hi bullet, those are definitely helpful, thanks! The video and tree I posted were of the effect I wanted to achieve (but with particles). I was hoping to avoid using a single-axis push effect since the object I'll be deforming is more spherical than it is planar and the particles will be approaching from all angles.
noodleman
Post by noodleman » 11 Sep 2013, 11:56
I think I figured it out. It might require a few tweaks, but this more or less does the trick:
Post by Bullit » 11 Sep 2013, 17:50
I see now that you wanted to do the deforming with instances - my fault due to speed reading - i'll have to test this since it is an effect i think it is interesting.
noodleman
Post by noodleman » 25 Sep 2013, 19:21
Now that I've figured this out, I seem to be having one more problem: This effect requires a simulated ICE tree, but I'd ultimately like to add a shape animation to this affected geometry. Unfortunately, ICE simulation kills the animation stack. Is there a workaround for this?
Post by Bullit » 26 Sep 2013, 13:29
You can cache and then read it in another ice tree and deform. Before that try the Post Simulation stack in the ice tree.
