anyone know if there is a way to convert one of my files to an stl file?
I found someone with a 3D printer, and apparently that is what they want the format to be in...
.stl file?
Re: .stl file?
I have absolutely no experience with these kinds of things,
but you could take a look at the "open sourced" Meshlab.
Re: .stl file?
you can use "Deep Exploration" or "Polytrans" for this task. Or even Rhino, they have a demo with 10 or 20 file export ;-)
csaez
- Skype: csaezmargotta
Re: .stl file?
Hi, there's a recent discussion on this topic in the mailing list
https://groups.google.com/d/msg/xsi_lis ... _Bpq4Pv2MJ
Re: .stl file?
It would all depend on how often you are planning on doing this, obviously,
but "Polytrans" and "SAP Visual Enterprise Author" (formerly known as Deep Exploration, apparently)
would seem to be slight (financial) overkill as there are many cheaper options you can try before resorting to buying one of those...
Re: .stl file?
I wonder if Autodesk 123D has fbx i or other import? It's made for 3d printing so there must be the right kind of export
Re: .stl file?
Nice catch!luceric wrote:I wonder if Autodesk 123D has fbx i or other import? It's make for 3d printing so there must be the right kind of export
123D apparently supports OBJ import and STL export.
Who would have guessed that on an Autodesk related forum
we could successfully have overlooked this little tool...
Shredder565
Re: .stl file?
how about downloading a student version of max or maya? would either of those open up a softimage file and export into an stl?Hirazi Blue wrote:It would all depend on how often you are planning on doing this, obviously,
dwigfor
Re: .stl file?
I noticed last night that Photoshop CC can also export STL
AceMastermind
Re: .stl file?
There is an *.stl export script for Softimage here, written in Python by Vladimir Jankijevic.
Re: .stl file?
I'm not sure if would trust just any random stl exporter. Surely there must be some intelligence built in an app that's made for 3D printing to produce proper files
