How do I access the returned value from this command
Pete
Post by Pete » 05 Sep 2013, 06:56
Hi there,
Sorry to have to ask such a stupid question but in this example -
// Returns 1
Application.LogMessage( StringSearch( "foo", "o" ) ) ;
how do i access the return value. I'm trying to check for a match in the string but I just can't seem to get anything to work.
Pete
myara
Re: How do I access the returned value from this command
Post by myara » 05 Sep 2013, 07:01
I'm not sure what is "StringSearch", or foo, or o, or "Returns 1", but it seems you are using JScript. If you want to search something in a string in JS you can use search or indexOf. You also have lastIndexOf.
var string = "This is a test"
var search_test = string.search("test")
var indexof_test = string.indexOf("test")
M.Yara
Pete
Post by Pete » 05 Sep 2013, 07:15
Thanks myara! Works great :)
