change expose type of exposed port properties
clankill3r
Post by clankill3r » 04 Sep 2013, 19:17
How can i change the expose type in a ice compound?
If i change from single to anything else i get:
' WARNING : Cannot set the expose type of the port to the requested value.
Re: change expose type of exposed port properties
Post by Daniel Brassard » 04 Sep 2013, 20:14
What is the port connected to (node)? If the node port does not support multiple instance it will not allow you to set the port type.
http://download.autodesk.com/global/doc ... d30e271450
clankill3r
Post by clankill3r » 05 Sep 2013, 03:32
thanks. I was using the wrong node.
