Custom ICE Node
grreez
Skype: soliloquy
Custom ICE Node
Post by grreez » 29 Aug 2013, 15:09
Hi
Are there any good ICE nodes resources I can download.
The factory nodes are nice but sometimes i need things to be done faster.
I need to remap a non-uniform UV coordinates to uniform space on a curve in ICE.
i have attached screenshots.
I am building a fence compound and use the uv to layout node to generate the positions on a curve. As you can see on the second picture a gets stretched and all the point positions are getting messed up.
Does anyone know a solution?
grreez
Skype: soliloquy
Re: Custom ICE Node
Post by grreez » 30 Aug 2013, 09:50
I wonder why nobody puts any comments :(
Anyway
I have found the solution to fix the odd parametrization of curves, uneven spread of uv's.
Modify curve/re parametrize/cord length which fixes the problem although some more things will have to be done to make the fence look perfect.
mattmos
Re: Custom ICE Node
Post by mattmos » 30 Aug 2013, 10:02
Hands down the best resource for ice compounds is here:
http://www.rray.de/xsi/
If you search for curve, there is a more even spacing compound by Julian Johnson that might be useful, but broadly, your approach is the right one, making the curve parametrization more equal.
grreez
Skype: soliloquy
Re: Custom ICE Node
Post by grreez » 30 Aug 2013, 13:42
mattmos wrote:Hands down the best resource for ice compounds is here:
WOW
Thank you.
