ultimapper baking AO - white parts in stick area
flashgordy
Post by flashgordy » 25 Aug 2013, 13:17
Hi
when I bake AO with ultimnapper, results are strange.
In areas where two object stick together- should be baked in to black - like in Blender or other aplications.
In Softimage I have white color...why? I should change something in object props or something else?
this is irritating because I have color leaking and must fix in Photoshop...:/
AceMastermind
Re: ultimapper baking AO - white parts in stick area
Post by AceMastermind » 25 Aug 2013, 23:35
Ultimapper is for transferring detail from hi-res objects to low-res objects. Your image suggests that the objects were already low-res. You should just use RenderMap to generate the AO.
flashgordy
Post by flashgordy » 26 Aug 2013, 18:58
YES !!
thanks man !
