Cubify Sculpt
Cubify Sculpt
Post by Bullit » 17 Aug 2013, 14:13
http://cubify.com/sculpt
Features
Design from scratch starting with a box, sphere or cylinder of virtual clay.
Import: STL, OBJ, PLY, CLY to edit
Export: STL, OBJ, PLY, CLY, ZPC
Cubify Sculpt saves as a 3D print-ready STL.
Use push and pull tools to sculpt your digital clay. Adjust the strength and size of the sculpting tool for exact cavities and extrusions.
Design with symmetry when modeling a face or figurine.
Deform and reform your model by squishing and pulling whole objects.
Emboss with patterns and textures. Choose from Cubify Sculpt's library or import your own displacement map.
Add color with the paintbrush feature. Get your full-color design Cloudprinted with Colorstone material.
Re: Cubify Sculpt
Post by Hirazi Blue » 17 Aug 2013, 14:46
Might be enlightening to add that it apparently costs $129. ;)
AceMastermind
Re: Cubify Sculpt
Post by AceMastermind » 17 Aug 2013, 18:55
Free online basic sculpting alternatives: Blender also has some nice sculpting tools. DrPetter's Sculptris is another good free sculpting app available through Pixologic.
oglu
Re: Cubify Sculpt
Post by oglu » 18 Aug 2013, 12:51
or meshmixer...
Pancho
Re: Cubify Sculpt
Post by Pancho » 19 Aug 2013, 08:10
Sculptris. Even if it has been said already. Top notch. Especially in combination with zBrush.
dwigfor
Re: Cubify Sculpt
Post by dwigfor » 20 Aug 2013, 17:47
AceMastermind wrote:Free online basic sculpting alternatives: Blender also has some nice sculpting tools. DrPetter's Sculptris is another good free sculpting app available through Pixologic.
Thanks for suggestions. I was intrigued by this Cubify Scupt as an i/o for PLY and STL files. No way to export/import those in Softimage. I think I had problems running that sculptfab in my browser (IE10, I think), but the sculptgl ran and also supports PLY and STL import/export.
Re: Cubify Sculpt
Post by Daniel Brassard » 20 Aug 2013, 21:33
Hi dwigfor,
Try MeshLab, it import/export PLY and STL files and you can bring the file in Softimage as an OBJ, 3DS or COLLADA via FBX.
Input/output in many formats:
import:PLY, STL, OFF, OBJ, 3DS, COLLADA, PTX, V3D, PTS, APTS, XYZ, GTS, TRI, ASC, X3D, X3DV, VRML, ALN
export:PLY, STL, OFF, OBJ, 3DS, COLLADA, VRML, DXF, GTS, U3D, IDTF, X3D
Point Clouds support. Now 3D files that are composed only by points are well supported in PLY and OBJ format.
U3D support; MeshLab is the first open source tool to provide direct conversion of 3D meshes into the U3D format. Now you can create pdf, like this with 3D objects with just MeshLab and LaTeX.
http://meshlab.sourceforge.net/
Dan
dwigfor
Re: Cubify Sculpt
Post by dwigfor » 20 Aug 2013, 22:31
Thank Daniel. Forgot about that. I used it a while ago and forget what problems I had with it.. Meshing a point cloud? I think I generated a ply file from a 3d scan via kinect, but couldn't convert the points to triangles. I'll have to give it another shot.
