hello guys,
I want to create an animation,
I have a tube, cylinder
the tube, it is seen from above, one sees a circle ....
then, the wheel and is positioned vertically,
when it starts, it must ortographic, when it rotates and is positioned vertically, prospectively.
I can not animate the cam, can you help me??
thanks
heeeeeeelp!!! ortographic to prospetcive animation
M3DParma
- Skype: M3d Parma
myara
Re: heeeeeeelp!!! ortographic to prospetcive animation
I don't think you can, but you can play with your FOV. Decreasing the FOV to a very low angle should give you something very similar to an orthographic camera.
Animating FOV and your camera work at the same time, would be something like the Dolly Zoom (Hitchcock zoom), and that could be a little challenging depending on your camera work if you do it manually.
M.Yara
caledonian_tartan
hitchcock?
try this!
try this!
SI 2015 @ WIN7-64
M3DParma
- Skype: M3d Parma
ok, I'll try 'vertigo ;) ... but ..
I created an animation capture, avi files,
I see now include it here for you to see the problem
http://www.flickr.com/photos/100253468@N05/9507463509/
You could do two animation shots, one orthographic camera view (from large view to small far away view, say frame 0 to say 100), switch camera to perspective (from far away to near, say frame 101 to frame 200). Make sure both camera are at the same location (could be the same camera). Assemble both shots in the FXtree.
M3DParma
- Skype: M3d Parma
tnx to all,
caledonian_tartan, ho to use compound?
