I've completed a bunch of character animations. I initially had the character (in different poses) approved prior to animating it, but now the client wants the upperarms to be longer.
I've always had a weird time doing this even with no animation - what is the proper way to do it, without affecting the overall animation either at all or too much. If possible at all?
Altering proportins after animation
Zafar Iqbal
- Zafar Iqbal
Re: Altering proportins after animation
Creating an Action Source from your animation, perhaps, and reapplying it after your modifications to the model? I think this should work as long as the structure of the rig doesn't change...
myara
to edit bones just mute the envelope, move your bones (hopefully you are using nulls ), select your mesh and bones and reasign the default pose or whatever that function was called, unmute envelope and you're done to edit your rig now.
I wrote something for this
http://vimeo.com/m/40661907
M.Yara
Zafar Iqbal
I'm already relying on Action Clips and tweaking the joints (Ctrl+J) is trivial to work with. I can tweak the upperarm, but then have to reposition lowerarm/hand. when I do this, the entire arm rotates in an undesired angle.
The rig is Biped Rig and unfortunately, no nulls bewteen the bones.
- Zafar Iqbal
