mirror animation
Zafar Iqbal
mirror animation
I have a character set up using Biped Rig. I'd like the mesh and animation to mirror completely. Scaling on X messes it up and I've tried plotting the constraints and animation, but didn't have luck with that either.
Can it be done?
Can it be done?
- Zafar Iqbal
gustavoeb
- Skype: gustavoboehs
Re: mirror animation
for my mirroring animation needs I use Gear. it has a nice template generator that stores how mirroring should be handled on a per object basis.
the code on the site used to have a little bug, Jeremie released a update in the SI mailing list. here is the link:
https://groups.google.com/d/msg/xsi_lis ... VJFqf7GeoJ
Gustavo Eggert Boehs
myara
The standard procedure, if youre not using specific scripts like gear which is awesome btw, would be to copy the animation, and in the fcurve editor, flip a fcurve (usually posx). To flip the curve, just select all the keys in the curve, and multiply them by -1.
Im not in front of my PC but i think it was -1 *
I think i wrote a simple script for this but Im not sure if it still works fine, havent used it in a while.
http://vimeo.com/56902800
M.Yara
Zafar Iqbal
Thanks a bunch - but I have no idea how to use this.
I tried loading it up in script editor, selected everything I needed to mirror and then ran the script but got error on line 37.
Line 37 says "import gear" - I then found and installed the Gear add-on but that didn't help either. The docs says after installing, "Gear" appears between "Display" and "Windows" in the menu. It does not. Tried re-installing, but SI tells me it's already installed.
- Zafar Iqbal
Zafar Iqbal
gustavoeb
sorry zafar, my post was a bit misleading. one needs to go through all the process of installing gear AND THEN find the broken python file inside it, AND THEN exchange it for the one I posted the link to.
the price is higher, and I didnt even mention you will have to setup that template I talked about for all controllers in your rig. on the flipside once you are done it is a one click solution. so I would go with myaras's solution if you need to do this every now and then, and would go through the gear route IF it is some complex character with many controllers and you intend to use this feature daily.
Zafar Iqbal
Thanks for clarifying. This particular animation is somewhat simple. Cloning and applying negative scale on the clone works, but small tweaks are for some reason needed. I think I'll take that route.
- Zafar Iqbal
AceMastermind
mMirrorFCurve.xsiaddon
Does anyone happen to have a backup of mMirrorFCurve.xsiaddon on their harddrive? The 4shared link at the video is invalid and i'd like to give this addon a try.myara wrote:I think i wrote a simple script for this but Im not sure if it still works fine, havent used it in a while.
myara
Im on vacations(very short vacations) but I'll check when I get home,
meanwhile you can try with this
https://www.dropbox.com/s/2hlbkknecwb1g ... rFCurve.js
Just remember it was an experimental script that isn't finished yet
M.Yara
csaez
- Skype: csaezmargotta
That works on simple FK animations, but imagine a character walking in a non orthogonal direction and try to mirror his IK leg with your procedure...myara wrote:The standard procedure, if youre not using specific scripts like gear which is awesome btw, would be to copy the animation, and in the fcurve editor, flip a fcurve (usually posx).
Mirror a pose implies more than copy+negate fcurves, you will probably need a reference object (COG/hips), a symmetry template and some linear algebra to calculate the space switching.
myara
In my short experience, negate fcurves method works in lets say 80% of the cases. In the 20% of rest, the animator isn't moving the rig root but the legs or arms controllers individually. In this case the controller's animation isn't mirrable with this method because they aren't symmetrical in relation to their parent object.csaez wrote:That works on simple FK animations, but imagine a character walking in a non orthogonal direction and try to mirror his IK leg with your procedure...
You can wokraround this with temporal nulls, constraints and plot animations to convert the animation to a local space based in the hip or whatever like you said but avoinding doing all that math. You can script it easily and fast. It works for me.
M.Yara
AceMastermind
Thanks!myara wrote:Im on vacations(very short vacations) but I'll check when I get home,
It looks like the Japanese strings in the code didn't quite make it through translation. Will this affect how the script works and is there any chance of localizing it in English?
myara
I wrote an eng/jp version.
https://www.4shared.com/file/1EvI2FYe/m ... Curve.html
I wrote a mirror copy fcurve, mirror character tool for a project, but it was heavily dependent on the project naming convention and rig structure. This is an stripped version to make it a little more general, I was still trying different approaches to make it more technical friendly, reusable and a GUI more intuitive, but I had never find the time to finish it. Maybe someday.
A few days ago Stephen posted a vimeo movie with a similar tool and the minute I saw it "Now I don't have to finish this tool ! Wooohooo!! I'll just use this and modify it to my needs", I though but then I realized there wasn't any download link so I guess this isn't free or available.
M.Yara
