How do I reference a rigged/weighted model in a scene?
Filmguy
Post by Filmguy » 09 Aug 2013, 21:06
Hi Guys. Were currently doing character animation for a series but would like to have a referenced master character that we animate in the scenes.
The trick is that I would like to reference a rigged and weighted model in a scene (like Maya's reference object) and the model exporter only allows for 1 selection e.g. either the model or the rig and not both. Any way to to do this?
sonictk
Re: How do I reference a rigged/weighted model in a scene?
Post by sonictk » 09 Aug 2013, 23:28
? You should be able to convert any selection of objects in your scene to a model at any point. (Create > Model > New Referenced Model). Once you do that, you can see the new Model in your Explorer and you should be able to export that to anywhere you want as a .emdl to be referenced into any other scene. What kind of rig setup do you have?
myara
Post by myara » 10 Aug 2013, 01:42
You can only export one model node. So put your model and your rig model inside a new model node and export as emdl.
M.Yara
Filmguy
Post by Filmguy » 10 Aug 2013, 12:27
Thanks Myara. I actually started playing around with it and got it to work the way you described :)
