Please help with strange normals.
synergy11
Post by synergy11 » 08 Aug 2013, 21:32
I am getting weird seams in my normal map. This is just a basic trim baked down into a tilable trim texture which I then projected on my window model.
I've done this before in Softimage. I'm not sure why it is giving me a problem now.
The screenshot will show the result and set up.
I used Ultimapper.
I'm getting this seam at each of the four corners. But there is no actualy seam in my normal map!
Any help would be greatly appreciated.
Thanks.
Rares
Re: Please help with strange normals.
Post by Rares » 29 Aug 2013, 17:19
Hi synergy11,
You already have a tangent property and that it's pointed to in the tangents subsection of the xsinormalmap ppg? Try unchecking unbiased normal map and unbiased tangents. Check your polygon normals also to make sure they're consistently pointing in the right direction, your case being roughly towards camera.
This video by Manny should provide some useful clues; https://vimeo.com/19399592.
Good luck.
