luxodrome
JohnGardner
luxodrome
Post by JohnGardner » 31 Jul 2013, 14:20
I am trying to create a luxodrome in Softimage, but I am not having much luck locating a solution. Is anyone aware of an ICE compound that will create a luxodrome/rhumb?
Here are some technical resources...
http://en.wikipedia.org/wiki/Rhumb_line
http://www.mathematische-basteleien.de/spiral.htm (scroll down & look for loxodrome)
Thanks,
John
Re: luxodrome
Post by Daniel Brassard » 31 Jul 2013, 16:41
Very easy in ICE. It is a variation of the helical torus compound.
You already have the parametric formula. The loxodrome is a curve on the sphere, which cuts the meridians at a constant angle.
The parametric representation in Softimage is:
x= cos(t) * cos [1 / tan(at)]
y= - sin [1 / tan(at)]
z= sin(t) * cos [1 / tan(at)]
where a is constant of your choice and t the variable parameter.
Just download my ICE Topo Pack and modify the helical torus compound to match the formula above.
https://www.si-community.com/forum/v ... =19&t=2269
Not in front of Soft at this time but can post the ICEtree tonight.
JohnGardner
Re: luxodrome
Post by JohnGardner » 31 Jul 2013, 18:33
Great, thanks!! :)
Matic
Re: luxodrome
Post by Matic » 01 Aug 2013, 01:24
The "phi" emitter I post on my site http://andy.moonbase.net/archives/1128 here also touches on this.
Re: luxodrome
Post by Daniel Brassard » 01 Aug 2013, 04:20
Here you go.
I used the equation on Wolfram for this representation.
http://demonstrations.wolfram.com/LoxodromeArt/
Re: luxodrome
Post by Daniel Brassard » 01 Aug 2013, 04:29
The compound
Re: luxodrome
Post by Daniel Brassard » 01 Aug 2013, 05:02
You can also model very quickly the shape using a sphere
first create a sphere with enough subdivisions (24 x 24)
triangulate the sphere
delete every x polygons along the sphere in the Loxodrome pattern
Apply thickness, subdivide, render
JohnGardner
Re: luxodrome
Post by JohnGardner » 01 Aug 2013, 13:26
Thanks Daniel!
JohnGardner
Re: luxodrome
Post by JohnGardner » 01 Aug 2013, 14:07
Thanks Matic!
Re: luxodrome
Post by Daniel Brassard » 01 Aug 2013, 18:38
And here is another version, graciously provided by Stephen on xsisupport blog
http://xsisupport.com/2013/07/31/ice-loxodrome/
So many ways to skin that cat! :D (the loxodrome ... not Stephen) =))
