Hello i'm looking for an instruction to do a button which swap between IsolateSelected(null, 1); and IsolateAll(null, 1);
i think i have to use a script similar to this :
var pref = GetValue("preferences.Polygon.planarity" );
SetValue("preferences.Polygon.planarity", !pref, null);
if someone have got something this would be very useful. Thanks
Script button for IsolateSelected and IsolateAll
kcsaba
- Skype: csabakanal
Re: Script button for IsolateSelected and IsolateAll
Wouldn't be easier to simply map the commands in the hotkey editor? I have alt f1/f2 works perfect for me.
csk
myara
I haven't found any way to know if an object has been isolated or a view is isolating something. So you would need to create something to get this info, like a custom property to know when to change from Isolate to Unisolate (IsolateAll).
Now, IsolateSelected works with only one view, so you would need to check what view are you using now, and what view did you use to isolate.
The code wouldn't be 2 lines, but about 30~40 maybe.
A basic code working with only 1 view:
BTW you could use ToggleValue for your planarity code. Apart from being a one line command it doesn't have any advantages though.
var r = ActiveSceneRoot
if (!r.properties("iso") && selection.count >0){
IsolateSelected();
oPSet = r.AddProperty("CustomProperty", 0,"iso");
else{
IsolateAll();
if (r.properties("iso")) DeleteObj(r.properties("iso"));
}Code: Select all
ToggleValue("planarity", "preferences.polygon")
M.Yara
csaez
- Skype: csaezmargotta
IsolateSelected without anything selected does the same than IsolateAll
myara
OMG! thanks!csaez wrote:IsolateSelected without anything selected does the same than IsolateAll
All this time I've been clicking the [X] button.
M.Yara
Val_west
Thank you. it's working too good.
