Hello people,
i am trying to find out the best way to have a rose to be carried from a character during lots of shots, the rose it hugelike from a human hip to toes, lets say something like the size of an umbrella or a regular stick.
I have tried with normal bone rigging, mt springs, ice springs and meshless deformation, but the situations are two wide and i need a flexible solution, the rose need to be fluffy and react to gravity and so on.
If anybody as some ideas to share would be really apreciated.
thanks
ROSE RIGGING
Helli
Re: ROSE RIGGING
I would build a normal rig for it with some springs in it.
why did mt_spring not work ?
You got gravity and the possibilitie to blend between animation and simulation so that should give you the control oyu need no ?
hidalgo
Re: ROSE RIGGING
unfortunatly mt spring doesnt consider collisions and secondly mt spring doesnt give that "fluffy" look i am after for the petals and its almost uncontrollable.
mattmos
Re: ROSE RIGGING
I'd prob go with syflex for what you're describing, using a stiff version as a source shape and painting more flex in along the length of the petal. Avoiding self collision if poss though, just outer sections collide with external objects.
hidalgo
Re: ROSE RIGGING
believe it or not i have tried with syflex too, but even syflex (with a mimic) seems to not give the type of controll i need, the stem for example, bounce like crazy all over the place as soon as you start moving it, due to the natural spring of syflex.
i would need something who can keep better the shape of the original rose, letting it look more like rubber or plastic more the a peace of cloth.
mattmos
Re: ROSE RIGGING
Sorry I thought you were talking about the petals only - I wouldn't use syflex for the stem. mt_spring for any secondary stuff probably, and hand animating collisions (easy to blend in and out of sim using it anyway).
Moderator edit: this topic has been moved twice now, sorry - HB
hidalgo
Re: ROSE RIGGING
i should try that way then cause any solution as provide not enough quality and control at the same time, i forgot to mention i used momentum too
Thanks for the tips, if anything else comes up i would be more then glad to hear it.
