interactive car rig
julius
interactive car rig
Post by julius » 21 Jul 2013, 21:44
Ok,
I'm trying to make an interactive car rig to learn a bit more rig/simulation, and I have two problems :
firstable, when I use a fixed constraint between two simple cubes, all is fine with default settings, but when I apply the same thing between the four little cubes you can see in the video, and the big one in the center, all is shivering... The only thing I found to solve it is to raise to 100 the substeps number in the physx dynamic operator. Is it normal ? :-?
My second probem : I applied a hinge constaint between my wheels and my little cubes. The behavior of the wheels seems ok, but hinges are rolling all the time....
What's the problem ? :-??
here is a little video to show you concretely :
thanks for your advices.
PS : thanks to moderator for editing the video ID
julius
Re: interactive car rig
Post by julius » 23 Jul 2013, 10:11
Ok,
I experimented a bit more, and it seems that shakes appears only when there is a significant difference between the respective sizes of the objects.
If volumes are approximately the same, there is no problem anymore...
any idea please ?
julius
Post by julius » 23 Jul 2013, 21:30
Ok, so it seems that simulation specialists are not on si-community ;)
I try a last question as I didn't succeed on driving a specific rotation axis of an active rigid body. Is it possible ?
Post by xsisupport » 23 Jul 2013, 21:56
Did you see this article on andynicholas.com ? Building A Car Rig
// Steve Blair
julius
Post by julius » 24 Jul 2013, 11:54
Thank you, I've seen it, but my goal is to build a rig able to do things like that :
That's not the case of the Nicholas's one.
olivier jeannel
Post by olivier jeannel » 31 Aug 2013, 15:29
What are you using for your RBDs simulation ?
I'm making a falling car (a simple one) kind of "ragdoll" with Momentum and it's working good enough atm.
julius
Post by julius » 02 Sep 2013, 21:49
I'm using native RBDs simulation tools, not ICE.
olivier jeannel
Post by olivier jeannel » 03 Sep 2013, 08:18
Did you manage to get somehing working ?
julius
Post by julius » 04 Sep 2013, 21:00
No, I didn't find any solution to constraint the simulated wheels orientation during the simulation.
Maybe ICE is the solution, but I'm a total beginner with it.
