Maths problem.. weighting points by proximity to tester
Pooby
Post by Pooby » 17 Jul 2013, 15:50
Hi, I posted this on the Softimage mailing list, but I'll ty here too.
I have a selection of points (not on a flat plane) and I have a test position.
It returns an array that represents the weighting, related to the proximity to the other points.
I want to have it so that when the test position is directly at a point, the value for that point in the array = 1
and the rest will be zero
as the test point moves around the area it interpolates these values, but they always add up to 1
It sounds really easy, but I’ve been literally* tearing my hair out over this for days.
Ive managed to get barycentric interpolation working for a flat plane, and only 3 points, but I need it to accept multiple points in 3d space.
Please help. I’m going bonkers over this
Paul
*(not really literally)
Re: Maths problem.. weighting points by proximity to tester
Post by rray » 17 Jul 2013, 16:31
Would an array of the (1/distance_to_point) values work? (Normalized by dividing each array element by the array's sum)
You would also have to check the special chase if the distance is = 0 to some point.
Post by rray » 17 Jul 2013, 16:34
Btw, should a point C ....
---(line)--------A--B--C-------(line)-----
have 0 influence by point A and 1 influence by B (like "shadowed" by B)
or (1/3) A and (2/3) B?
Pooby
Post by Pooby » 17 Jul 2013, 18:16
Yes that's very tricky scenario. I'd be happy to have a solution that just works with all the points making a convex shape, so no shadowing.
Imagine a cube-like structures points, and a test position moving within, finding the weighting array to each of the eight points.
That will probably suffice, although a comprehensive solution to any scenario would be nice, if it's mathematically possible
Pooby
Post by Pooby » 17 Jul 2013, 18:28
Two of us have been thrashing this out for days.
I'll give a full day of my cgi time on your project as a prize to whoever can solve it satisfactorily. ( as long as your project doesn't require me to give away proprietary secrets)
Post by rray » 17 Jul 2013, 18:29
Pooby wrote:Yes that's very tricky scenario. I'd be happy to have a solution that just works with all the points making a convex shape, so no shadowing.
Then the (1/distances) normalized thingy should probably work ok enough.. would have to test
Pooby
Post by Pooby » 17 Jul 2013, 18:47
It was my first port of call too but it doesn't work.
Say you have 1 point at zero and two others at .5 and .5
When you reverse that, you get 1 and .5 and .5
Normalise that and you get 0.5 and 2.5 and 2.5
Post by Mathaeus » 17 Jul 2013, 20:23
Pooby wrote:It was my first port of call too but it doesn't work.
There are factory nodes, doing that already, like 'calculate deformer weight', or hair filler node. At least in these nodes, formula is something like:
1:subtract the point position from array of positions
2: length, or squared length of subtract
3: invert
4: divide invert by summary of inverts (to get them normalized)
So, 'invert' seems to be key, there you should get something like 0.998 at least.
Anyway, as RRay said, really, really should be some switch for zeros. Otherwise, there's danger of having an entire destructive chain of problems.
edit: 'invert' in ICE, when it comes to number (scalar), is a multiplier, needed for getting the 1 - let's say, it's 5 for 0.2. Generally ( really generally) there's some exponent, square root, invert or similar thing in such calculations.
grahamef
Post by grahamef » 17 Jul 2013, 20:57
I'm attaching a scene (v2013).
Pooby wrote:Say you have 1 point at zero and two others at .5 and .5
That's the special case when distance = 0 that rray mentioned above (and I mentioned on the list).
Pooby wrote:When you reverse that, you get 1 and .5 and .5
You need to invert, so it would be 1/0 = undefined, 1/.5 = 2, 1/.5 = 2. The 1/0 is why you need to treat it as a special case.
Pooby wrote:Normalise that and you get 0.5 and 2.5 and 2.5
If you did have 1, 0.5, and 0.5, then to normalize you'd first get the sum which is 2. Then you'd divide each value by the sum, giving .5, .25, .25.
rray wrote:Btw, should a point C ....
It should be (1/3) A and (2/3) B. Otherwise every point to the right of B would have the same coordinates (0, 1) and would be indistinguishable. That's not a very good coordinate system.
EDIT: Cross-posted with Mathaeus.
Post by Daniel Brassard » 17 Jul 2013, 21:36
Various formula that can be use for this effect:
* Cosine function mapped between 0 and Pi/2
* blend function
* inverse square root distance weighting
* logarithmic function mapped between 0 and 1
* smoothstep function 3t^2 - 2t^3 or 6t^5 - 15t^4 + 10t^3
Some of these functions will go to infinity at case zero or one, you will have to test these cases and force the result (to 1 or zero depending of the function). One way to solve this is to restrict the mapping between .00001 to .9999 and force 0 and 1 outside the mapping range.
Have you tried to use an fCurve mapped between 0 and 1?
Pooby
Post by Pooby » 18 Jul 2013, 06:40
Thanks very much for the replies. Very much appreciated and I will check out the scene later at work.
I was already adding .001 to avoid divide by zero errors, but it didnt help me get anything useable.
I will look up those functions later too.
However, frustratingly for me, trying to decifer maths formulas is not something I can easily do with my current math skill set, unless they are very basic indeed . I spent a day trying to decifer a PDF that looked like it had an answer, but with absolutely no background in maths notation I just ended up getting demoralised.
It felt like trying to translate a Chinese song to English, armed with some sheet music and a page of Chinese text. But with no knowledge of either music notation or Chinese symbols.
This is something I have to address, but it's going to take time so, at the moment, I need something idiot proof.
The irony is that some people often assume I'm good at math because of my ICE tutorials whereas I'm just making that up as I go, not even thinking of it in terms of formulas.
Pooby
Post by Pooby » 18 Jul 2013, 08:47
that was a typo on my part. I meant .25
Pooby
Post by Pooby » 18 Jul 2013, 08:56
The ICE tree has many unattached nodes when I open it. Are you using some custom node I dont have access to?
Post by Mathaeus » 18 Jul 2013, 11:36
Pooby,
so you got it to work, or not. What grahamef posted, I believe it's more or less the same as my procedure, one post above.
If you didn't, I'll post screenshot of ICE tree, this evening.
Pooby
Post by Pooby » 18 Jul 2013, 12:19
I am fiddling about now and it looks like I'm getting something useful using your idea of pulling the Calculate deformer weights apart and using the maths in there..
Thanks for that (and to everyone who posted for helping me out). I don't understand how it works, but it looks like its probably the way to go.
grahamef
Post by grahamef » 18 Jul 2013, 15:13
Argh. I uploaded the wrong one (had started in a different version for compatibility with more versions but then realized I didn't have Build Array from Set).
Sorry about that -- I'm attaching what is hopefully the correct one.
