"View B" default camera
keeper
How to setup default view of "View B" to something else than "Camera"? For example User view.
Re: "View B" default camera
For the shelf shortcuts you can right click the shelf button and add
vw.setattributevalue "activecamera:b", "User"
to the script commands
For the initial view I don't know, you'll probably need to create a custom layout with a different cam set it the view properties.
keeper
Found a solution. A simple custom "Startup" event plugin with code:
// Callback for the Startup event.
function Startup_OnEvent( in_ctxt )
Application.LogMessage("Startup_OnEvent called",siVerbose);
// TODO: Put your code here.
var views = desktop.ActiveLayout.Views.Find("View Manager");
views.SetAttributeValue( "activecamera:b", "User");
// Return value is ignored as this event can not be aborted.
return true;
return true;
AceMastermind
You'll probably want to add another event for when you start a new scene too, I use what you have plus this(in vbs though) so that view 'B' defaults to 'User' at all times after launching the application.
' Callback for the siOnEndNewSceneEvent event.
function siOnEndNewSceneEvent_OnEvent( ctxt )
Application.LogMessage "siOnEndNewSceneEvent_OnEvent called",siVerbose
' TODO: Put your code here.
set vw = Desktop.ActiveLayout.Views.Find( "View Manager" )
vw.setattributevalue "activecamera:b","user"
' This event can be aborted by returning true or false if you don't want to abort.
siOnEndNewSceneEvent_OnEvent = false
end function
