Multiple objects to one texture projection?
Post by Bullit » 14 Jul 2013, 21:29
Maybe i am asking a simple question but what is the way to this without merging all objects?
Edit: It seems that it works if i make a group and apply the projection to it, all objects in the group share the same projection.
Re: Multiple objects to one texture projection?
Post by ActionArt » 15 Jul 2013, 14:34
You can also apply a projection to one object, then select the next object and go to property>texture projection>connect to projection and then pick the projection of the first object. It's covered in the manual.
Hope that helps.
Post by Bullit » 15 Jul 2013, 18:15
Eugen
Post by Eugen » 16 Jul 2013, 06:43
By the way, you can apply any deform operator to a group of objects if you need it to be instanced (e.g. Bend, to share a common center across all objects).
It will be displayed in italics in the individual object's stacks, except the first. If you want to delete it, delete any of the instances.
ICE Trees however cannot be applied to groups, which I consider a design flaw.
Post by Bullit » 16 Jul 2013, 18:48
Yes, no ice trees in groups is a big issue.
Thanks for the deform information.
druitre
Post by druitre » 14 Nov 2013, 15:57
Can I ask something additional... how to apply one projection to multiple islands? Like in this example: it's one object where I'd want each cube to have a fitting cubic projection.
(this is a very simple example, I want to know this because it pops up in much more complicated situations where manually adjusting each island is not an option)
Post by Bullit » 15 Nov 2013, 01:48
I think it works if you go by each polyisland which would be a daunting prospect if you have too many. Maybe it can be scripted, which i know nothing about , or maybe even someone already did that script, or released a tool.
druitre
Post by druitre » 15 Nov 2013, 13:27
Like I said, manually creating subprojections per island is not an option - I'm talking about (tens of) thousands of islands. I found a tool - https://groups.google.com/forum/#!msg/x ... FXtYq1ZGUJ - but it doesn't do this. Or at least, I can't get it to do this.
Per-island-UV-ing, that would be a good description. Or 'normalize per island'.
