Simple question about connected edges
keeper
How I can exclude (marked with red on image) edges? I use "vertex to edge" attribute to filter edges.
Re: Simple question about connected edges
Maybe with a string and put those numbers in it.
Helli
Imho the cleaner way would be to create a cluster and get the edges through the cluster.
This way you can easily add/remove stuff from the cluster instead of adding numbers to a string.
Isn't easier to take numbers from string, i mean from the small quantity in this example?
face
Also possible is to get the size of the point neighbors array.
Is the size greater than 3, exclude...
face
face
