GetOutputTarget
caledonian_tartan
GetOutputTarget
Post by caledonian_tartan » 12 Jul 2013, 08:36
hello
i looked up the SDK and found "GetOutputTarget"
i would like to get all the ports logged that a particular node is connected to.
but i have some troubles to use this successfully...
SI 2015 @ WIN7-64
caledonian_tartan
Re: GetOutputTarget
Post by caledonian_tartan » 23 Jul 2013, 13:27
now i use this to get the connections of a particular node of the selected ice tree
from siutils import log             # LogMessage
for op in Application.Selection(0).ActivePrimitive.ConstructionHistory:
    if op.Type == "ICETree":
        ICETree = op
        # output port direction
        log("output ports")
        for node in op.Nodes:
            for port in node.OutputPorts:
                for connectedPort,connectedNode in zip(port.ConnectedPorts, port.ConnectedNodes):
                    if node.Name == "PPG_Connector":
						log("%s.%s -> %s.%s" % (node.Name, port.Name, connectedNode.Name, connectedPort.Name))
        # input port direction
        log("input ports")
            for port in node.InputPorts:
					if connectedNode.Name == "PPG_Connector":
how can i get the input value (string/reference) of a "get data" node of the SELECTED pointcloud??
here's a working example using the pointcloud name:
oTest = Application.GetValue("pointcloud.pointcloud.ICETree.PPG_Connector.PPG_Name_string")
print oTest
SI 2015 @ WIN7-64
csaez
Skype: csaezmargotta
Re: GetOutputTarget
Post by csaez » 24 Jul 2013, 07:28
You can get it from the parameters of the node :)
from siutils import si, log
for ICETree in si.Selection(0).ActivePrimitive.ICETrees:
    for node in ICETree.Nodes:
            for connectedNode in port.ConnectedNodes:
                for param in connectedNode.Parameters:
                    log("{0}: {1}".format(param.FullName, param.Value))
caledonian_tartan
Re: GetOutputTarget
Post by caledonian_tartan » 24 Jul 2013, 12:37
cool! this works, thanks!
thing is that it returns the value 4 times although it only has one input...
SI 2015 @ WIN7-64
