Need help with animated array
Pete
Post by Pete » 01 Jul 2013, 23:09
Hi there,
I was wondering if someone could help me out getting started with this, i imagine it's a pretty simple thing to do but I've only done really basic ICE flows so far.
What I want to do is spawn a point at x0,1,2,3, - 10 position on the grid but to have each point spawn a second apart.
This was going to form the basis of a more complicated animation but I cant even get the start bit working :)
Can anyone point me in the right direction?
Pete
Re: Need help with animated array
Post by xsisupport » 02 Jul 2013, 10:24
Maybe something like this?
// Steve Blair
Pete
Post by Pete » 03 Jul 2013, 01:55
Thanks Steve,
That looks like a great start!
Pete
Post by Pete » 03 Jul 2013, 12:29
Hey I set up a basic compound to emit a point per second, the only thing is I can't seem to speed the rate up.
If i change the 1.000 in Modulo by to 2.00 for example it doesn't work at all. Hmmm i think it might be tied to the framerate.
and here's the compound if anyone wants to check it out.
http://www.naffupdate.com/forumfiles/Em ... sicompound
Pete
nixx
Post by nixx » 03 Jul 2013, 14:34
Pete wrote:Hey I set up a basic compound to emit a point per second, the only thing is I can't seem to speed the rate up.
Don't you have to lower the Modulo By value, if you want more points ? It doesn't control the rate, but the interval (the opposite).
Also, you might want to work with Current Frame instead of Current Time (=seconds), because with Time, it's easy to fall into decimal frames - and then they won't be evaluated, at least in a default ICE tree.
I 'm child, and man, and child again; the boy never gets older.
my Vimeo
Pete
Post by Pete » 03 Jul 2013, 22:50
Yeah, that's the value i was lowering. And for some reason it's wasn't speeding things up.
I switched it to current frame though and now it's much easier to understand and speed up.
Thanks for that.
