Cross Product Math in ICE
Falam
I have two spheres global position, plugged into a cross product then I set the data in a temp. When I view the position of both sphere (sphereA - 4.5168) x (sphereB - 12.8923) equals 58.2319 but my ICE results are -58.2296. A cross product is suppose to be A x B x (Sin) it doesn't appear ICE calculates the angle (Sin) of the cross product.
Re: Cross Product Math in ICE
A few things to check. What object is your ICE tree on? Is it at world zero (hint: It should be)? Did you normalize the position vectors before plugging them into the cross product node?
What are you trying to do with the result?
I'm confused should't a cross product be a vector not a number?
The cross product is a vector.
The magnitude of that vector is |A||B|sin(angle between A and B).
Falam
If don't mind, I'd like to see the correct method which you could then expand from.
