claudevervoort
Post
by claudevervoort » 27 Nov 2009, 02:00
Hi!
I am by no mean an ICE expert, but to push my knowledge a bit further I self imposed a little challenge: build a vine that grows on some geometry. You can see the final result
here.
I have gathered the steps I took to get the result in a PDF tutorial, in case you are interested. It can be found
here. That's only my take at it and all comments are welcome
Claude
Post
by Hirazi Blue » 28 Nov 2009, 08:32
Looks interesting! Thanks...
ace63
Post
by ace63 » 29 Nov 2009, 12:01
Thank you very much, stuff like this is always great for the community!
rconover
Post
by rconover » 06 Dec 2009, 03:46
Many Thanks Claude!
Any chance you could provide an example scene too?
The pdf is good for the theory-but I find that several of the images isolate the branches of your ICETree a bit too much. And there is nothing showing the Tree complete. So even having some idea what you are saying and having some ICE knowledge (but still learning) I find it a bit tricky to get valid results so far. Even in the early steps.
So I’d imagine an ICE novice should get quite lost. Reverse engineering (a finished scene) can go a long way.
many thanks again
ral
claudevervoort
Post
by claudevervoort » 06 Dec 2009, 22:48
Hi Ral,
That's good feedback
So I quickly assembled the 2 ICE main ICE trees. I've also zipped up the 2010 scene (
here) and the leaf quick morph image sequences (
here)
I hope this makes it a bit more digestible.
Claude
B-Maui
Post
by B-Maui » 10 Jun 2010, 10:33
that' s interesting!
if i only had it few weeks ago!!!
thanks to share!
talent103
Post
by talent103 » 19 Jan 2013, 23:31
Many Thanks! I will give this a try this week.
John
Eugen
Post
by Eugen » 15 Jan 2014, 17:53
Nice tool, thanks or sharing! (took me 4 years to notice = )
Eugen
Post
by Eugen » 15 Jan 2014, 19:59
Hi, a question:
I'm trying to pack the vine generator into a model for easy re-use, but the leaves cease to work then (branches are good). Looks like they remain at size 0. If I pull them back out, they grow properly again.
Any idea why? I'm checking all the get data nodes in the ICE tree, but cannot find the reason.
Eugen
Eugen
Post
by Eugen » 16 Jan 2014, 08:44
Allow me to give this a bump...
It would be very handy to have this example in a model, so it can be added quickly to a scene.
Problem is, that the leaves point cloud does not work properly any more when it is put into a model. I guess some name space problem.
My ICE knowledge is not profound enough to fix this - I tried.
Many thanks if anybody likes to have a look...
Best,
Eugen
nikaragua86
Post
by nikaragua86 » 16 Jan 2014, 23:32
yo raps, man, i`ve found a workaround of this bug - you pack the stuff into model, export it, then you open the scene that you want, import the model, and get the pointcloud_leaves out of the model into the scene root (or simply take all stuff out of the model into the scene root) - it works fine for me, write if you will(will not) succeed )))))
Eugen
Post
by Eugen » 17 Jan 2014, 10:52
Hi, thanks! That's what I'm going to do as plan B... = )
Best,
Eugen
