select polygon by angle?
hardgore
Post by hardgore » 26 Jun 2013, 18:58
is it possible in xsi?
i dont want to do it manually 8-x
Re: select polygon by angle?
Post by Hirazi Blue » 26 Jun 2013, 20:01
Don't know if this is exactly what you're looking for, but the RCTools offer the option to apply a custom selection filter based on angle.
hardgore
Post by hardgore » 26 Jun 2013, 20:44
Hirazi Blue wrote:Don't know if this is exactly what you're looking for, but the RCTools offer the option to apply a custom selection filter based on angle.
so which one is the select by angle?
dont know what to touch.
why it seems someting missing @-)
hardgore
Post by hardgore » 26 Jun 2013, 20:47
im looking for something like this
weird xsi cant do officially
it selects polygons at single click filtered by angle
Post by rray » 26 Jun 2013, 21:16
That rcTools page should look more like this
Maybe it needs a restart of the application.
You see the 'Orientation vector' in there which you can set from the current selection. After that set a maximum deviation angle like 1 degree, then tick the check box and click the 'select all' button.
When you don't want to use a plugin you could try rectangle selecting the polys from a side view with the 'surround polygon' option on.
hardgore
Post by hardgore » 26 Jun 2013, 21:53
rray wrote:That rcTools page should look more like this
why it look like this to me
no matter how many time i restart even i reboot
and is there no easy way??? ~x(
gaboraa
Post by gaboraa » 27 Jun 2013, 08:22
Just uninstal and go to the C:\Users\xxxx\Autodesk\Softimage_2013_SP1\Addons\InstalledAddons and delete rcTools.xsiaddon manually.
Sometimes it doesn't get deleted automatically and reinstalling wont work while the file is still present in that directory.
Hope it helps.
Post by rray » 27 Jun 2013, 10:08
See also the troubleshooting section on the download page. Easy way as I said is rectangle select from a side view with the surround poly option on.
hardgore
Post by hardgore » 27 Jun 2013, 13:28
surround poly is not im looking for this time...
theres lot of micro triangles almost invisible
because i use rhino a lot
rctool still same as before even on fresh install..... :-ss
and i got this error when installing the addon
' ERROR : 2356 - This plug-in is not installed: rcCustomFilterSettings
