Bake Implicit
Falam
Bake Implicit
Post by Falam » 20 Jun 2013, 04:49
Anyone know how to bake an implicit projection ? I've tried rendermapping, GATOR, nothing worked ?
Eugen
Re: Bake Implicit
Post by Eugen » 20 Jun 2013, 12:30
In the Texture_Projection_Def node, you can switch from implicit to explicit. See screenshot.
Is that what you are looking for?
Falam
Re: Bake Implicit
Post by Falam » 20 Jun 2013, 13:18
I made a typo, I meant explicit projection, when you type messages up at 1am :)
Eugen
Re: Bake Implicit
Post by Eugen » 20 Jun 2013, 13:50
So you want to freeze the texture operator stack?
In the Explorer, under Clusters > Texture_Coordinates_AUTO > Texture_Projection, topmost texture operator, RMB > Freeze.
Don't confuse this with the "Freeze" button in the Texture_Projection_Def node's PGG - it's only for "fixing" the UVW trafo parameters over there by applying a "ClsSetValuesOp" on top of the texture stack.
Using MCP > Edit > "Freeze M" of course freezes everything - geometry / texture / envelope weights stack.
If you think this is a tiny bit confusing... I agree! ; )
A "Freeze T" button in the MCP would be no shame.
Falam
Re: Bake Implicit
Post by Falam » 05 Jul 2013, 03:59
If you apply a implicit projection to a sphere, then try to rendermap the sphere, it won't work. I tried GATOR as well, hoping it would transfer, possible baking a UV projection.
