Falam
Post
by Falam » 14 Jun 2013, 15:29
VBScript
Set oRoot = ActiveSceneRoot
set oObjs = oRoot.FindChildren()
for each i in oObjs
logmessage i
next
JScript
var oRoot = ActiveSceneRoot
var oObjs = oRoot.FindChildren()
for (s=1;s<4=;s++){
LogMessage("oRoot")
All that is happening is the LogMessage command is looping 4x (JScript code).
Yet in the VBScript, things are completely different, what is the syntax difference ?
Edit: I want to squeeze in another question.
How can I offset objects in a loop. If I'm creating three primitives, and I want each one to have even spacing (JScript) ?
Post
by xsisupport » 14 Jun 2013, 15:58
The JScript equivalent of your VBScript is...
oEnum = new Enumerator( ActiveSceneRoot.FindChildren() ) ;
for (;!oEnum.atEnd();oEnum.moveNext() )
var oSelItem = oEnum.item() ;
LogMessage( oSelItem.fullname );
That's how you loop over the elements of a collection that you got from the XSI SDK (the JScript "for .. in" loop doesn't work on Softimage collections). In VBScript, however, you can use "for each".
In your JScript, you have a basic for loop that uses a counter variable.
// Steve Blair
// My Blogs:
Arnold |
Softimage
Post
by Hirazi Blue » 14 Jun 2013, 17:30
@Falam - As a general rule: don't try to learn
(or initially even try to understand)
several scripting languages at once.
Learning one can be tricky enough as it is.
Falam
Post
by Falam » 14 Jun 2013, 18:13
I would never learn more then one at the same time, I don't think that is wise for anyone to do. You'll only confuse yourself, to such an extreme. I'm only learning JavaScript (&ICE), I know Python is the "grande" language to learn, but I like JScript syntax
Thanks Stephen. I didn't know about that command, I guess it comes with learning
Post
by EricTRocks » 16 Jun 2013, 21:53
FYI JScript is NOT Java Script.
Falam
Post
by Falam » 17 Jun 2013, 03:03
EricTRocks wrote:FYI JScript is NOT Java Script.
JScript is a script language from Microsoft that is expressly designed for use within Web pages. It adheres to the ECMAScript standard and is basically Microsoft's equivalent to Netscape's earlier and more widely used JavaScript
Post
by Hirazi Blue » 17 Jun 2013, 08:13
The Wikipedia page for
JScript goes one step further, quoting "JavaScript guru" Douglas Crockford:
[Microsoft] did not want to deal with Sun about the trademark issue, and so they called their implementation JScript. A lot of people think that JScript and JavaScript are different but similar languages. That's not the case. They are just different names for the same language, and the reason the names are different was to get around trademark issues.
(my highlight), but then goes on to say there are some differences in implementation...
