I've come across several guides, tutorial and examples using (point) reference frames. So far I couldn't find any decent info. How do they work, how are they set up and what's their advantage?
Thanks for any help!
Pancho
Any infos on "reference frames"
Pooby
Re: Any infos on "reference frames"
they represent the axis of that point on the surface, so can be used for rotations.
Pancho
The point normal at frame 0? Or do I need to set the refernce manually (pointNormal > set reference frame)?
Pooby
No its nothing to do with the normal. Its an axis that ICE assigns. Its not a reference to any frame or anything like that.
I think its an odd name come to think of it.
http://download.autodesk.com/global/docs/softimage2013/en_us/userguide/index.html
Pancho
Thanks so much! Finally stumbled across a post on the google groups by Guillaume which also shed some light on it. Well, as you said. Its name is well off and misleading.
Cheers!
Cheers!
