I just wondered if there is a way to check cross sections of a model. Something like an interactive boolean. If for instance you model something like a neck or head and you want to compare your work to medical coss sections (e.g. MRT) it would be nice to see something like a slice of your model at the same location.
I could think of a very slow method of putting a grid into this area and get distances from the mesh to the model. This data could get transferred to another grid outside the model for inspection. This ICE tree would be quite simple, but everything depends of the resolution of the grid, making this thing very slow and pixeled.
I'd like to think of a way to use a null and what's inside of the null is visible, what's outside is not. If there would be a clone of the model, you could model and check cross-sections at the same time.
Anybody an idea?
Check cross-section (while modeling)
Toonafish
Pancho
Re: Check cross-section (while modeling)
That looks interesting. Combining two of those and I'm there.
