Hi community,
So... today to share a fcurve profile, i had to build an array of this profile and do some tricky tricks to filter my data with this.
Do someone has a better technique ?
Fcurve Share in an ice tree
Re: Fcurve Share in an ice tree
An F-curve can't be put in a compound?
Of course it can. But it's different than, for example, 'add' or 'multiply' node, because operation is 'built in'.Bullit wrote:An F-curve can't be put in a compound?
So, 'build array' of inputs before, 'select in array' after the node, I think that's all.
well, select in array is easy, but for strands it gets complicated, i've tried the generate sample set technique to avoid the repeat node but with no success...I don't even know if it is possible ;-) will re-try the next time i need it.
thanks
thanks
Pooby
Can you explain really simply what you want to do? I cant understand the problem
what kind of strands. If you're able to know 'in advance' how strands are distributed, there's trick to define the array of scalars first, save it as attribute, then use it in compound later, modulated by fCurve or something else - or well known "strand ratio", introduced in early tuts by Helge Mathe.NNois wrote:well, select in array is easy, but for strands it gets complicated, i've tried the generate sample set technique to avoid the repeat node but with no success...I don't even know if it is possible ;-) will re-try the next time i need it.
thanks
If strand array is generated by simulation, as particle trail or like, then... I don't know for (feasible) way of sharing.
Hi,Pooby wrote:Can you explain really simply what you want to do? I cant understand the problem
I actually wanted to simplify my ice trees...
I had, in different objects some fcurves nodes with the same curve, controling strands by their strandratio and just wanted to tweak all at the same time, so building an array of scalars.
It was just curiosity about how doing things...
The problem I was facing was modulating my strands by this "fcurve array" but they had different array size (different strand count).
So I was thinking i needed to resample my "fcurve array" to match my strand count but i haven't figured out how to do that...
Or, finding in that array but it involve a loop, or the generate sample set technique i've also haven't figured out how to make it work.
But, please excuse me for the noise (and my crappy english), i don't need this right now. I've managed it the old way ;-)
