scale in XSI
ibra
Skype: hendeweh
scale in XSI
Post by ibra » 07 Jun 2013, 00:16
how does scale in xsi work and does it affect lighting? should i model everything according to real scale? and how do i know real scale i XSI?
SamHowell
Re: scale in XSI
Post by SamHowell » 07 Jun 2013, 09:14
Ah, the endless question. This one never seems to go away and I have yet to hear a definitive answer. Everyone seems to have a different idea.
Yes scale can have a big impact on things in Softimage. Rigging, shading, simulations, shaders, displacement can all be dependant on scale.
Speaking for myself and the people I work with we tend to stick to the rule of 10cm is one Softimage unit. Just avoid making anything way too big or way too small.
ibra
Skype: hendeweh
Re: scale in XSI
Post by ibra » 07 Jun 2013, 12:25
found this: Throughout Softimage, lengths are measured in Softimage units. How big is a Softimage unit? It is an arbitrary, relative value that can be anything you want: a foot, 10 cm, or anything else.
which is useless really...
but then for simulation, they write : Always keep the scale of Softimage units and your scene objects in mind when designing a rigid body simulation. As with other simulation calculations, scale is crucial when dealing with rigid bodies. Before you start to do a rigid body simulation, you need to define what unit of measurement a Softimage unit will mean in your world: 1 meter, 10 cm, 1 cm, 1 foot, etc. And you need to model your objects in reference to this and to make sure that their mass or density also reflects this.
http://softimage.wiki.softimage.com/xsidocs/coordinates_SoftimageUnits.htm
http://softimage.wiki.softimage.com/xsidocs/rigidbody_GettingSetUpforRigidBodyDynamics.htm#Ree52073
i think sticking to your rule of 1 XSI unit= 1 cm is best for now :)
anyways... found this, hope it helps: http://zoltanocsai.blogspot.hu/2012/08/kcs-iceruler-091.html
thanks to Zoltán Ócsai!
Re: scale in XSI
Post by Daniel Brassard » 07 Jun 2013, 15:47
http://softimage.wiki.softimage.com/xsi ... m#Ree52073
1 SI Unit = 10 cm recommended (.1 metre)
Are you using IES Light profiles?
