freeze ice to geometry
clankill3r
Post by clankill3r » 06 Jun 2013, 12:58
I made a curve circle and a empty pointcloud. I added a sphere on every point position with add point.
Now i would like to freeze it so i can select the spheres. Is this possible?
Re: freeze ice to geometry
Post by Bullit » 06 Jun 2013, 14:18
clankill3r
Post by clankill3r » 06 Jun 2013, 15:10
cool thanks.
sad it isn't possible out of the box.
dwigfor
Post by dwigfor » 06 Jun 2013, 15:32
It is possible ootb via ICE Modelling. Pretty sure there's an example scene included too.
EDIT: Try using Create Copies from Polygon Mesh on empty polymesh. You'll need to create a primitive polymesh representing your instance to use in the ice tree, though. Also connect the pointcloud name.
clankill3r
Post by clankill3r » 06 Jun 2013, 15:54
what does ootb mean?
dwigfor
Post by dwigfor » 06 Jun 2013, 16:11
clankill3r wrote:what does ootb mean?
out of the box
Post by Bullit » 06 Jun 2013, 16:53
The video describes what you need to do. Note that the node usually works evern if it is red because you didn't give the materials.
CiaranM
Post by CiaranM » 06 Jun 2013, 19:21
Yes, it is possible out of the box, but is not wrapped up into a tool anywhere.
Here's an interesting discussion that comes up with several solutions.
