Hello,
How would I delete the Curve after I've turned the Curve into Poly Mesh ?
Curve to Poly Mesh
Re: Curve to Poly Mesh
You''ll have to freeze the generator input before you can delete it
From the manual:
From the manual:
Freezing Generators and Deleting Inputs
You can freeze the generator and delete the inputs. This simplifies the scene once you are satisfied that you won’t need to modify the inputs again.
To freeze generators and delete their inputs do one of the following:
• In the generator operator’s property editor, click Delete in the Inputs box. The property editor closes automatically.
• In an explorer, right-click on the generated object or the generator operator node and choose Freeze Generator & Delete Inputs.
• In a 3D view or a schematic view, Alt+right-click (Ctrl+Alt+right-click on Linux) on the generated object and choose Freeze Generator & Delete Inputs.
• Select the generated object, and then choose Edit > Operator > Freeze Generator & Delete Inputs.
ajhorvath
Thanks so much!!
dance
- Skype: barry.b.smith
Interesting i never read that i have always did it by duplicating the object and merging the two objects together and then selecting and deleting the original objects points then deleting the curve.
