Adjust Vertical Breaks in custom layout
Falam
Post by Falam » 31 May 2013, 11:32
I want to edit a customized layout whereas, the bottom vertical line can be dragged independently of the top vertical line. As it stands the vertical line that the red arrow is pointing at moves the vertical line for both the top and the bottom, the top being where the horizontal break is, with the bottom being the bottom of where the horizontal break is.
Re: Adjust Vertical Breaks in custom layout
Post by EricTRocks » 31 May 2013, 13:38
Your image is not showing up for me.
Eric Thivierge
Post by Hirazi Blue » 31 May 2013, 13:52
@EricTRocks - the problem would appear to be at your end, as the image is showing here just fine...
Post by EricTRocks » 31 May 2013, 14:36
You are correct. Internal proxies blocking it.
Eric Thivierge
Post by Rork » 31 May 2013, 15:11
try this:
-split horizontal first to get a top and bottom row
-split the top row vertically into two
-split the bottom row vertically into two
that should work for independent sliders.
From the image it seems you created a vertical split and filled in left and right with panels. But there's still one splitter for top and bottom.
Or am I mistaken?
Falam
Post by Falam » 31 May 2013, 15:30
Thanks Rork, works nice. As you mentioned, I didn't break the top half and the bottom half independently :)
Post by Rork » 31 May 2013, 15:42
Glad it worked! :-bd
Like I said, haven't done this in a while. ;)
