Semi-colon Error
Falam
Semi-colon Error
Post by Falam » 29 May 2013, 04:17
JScript
GetPrim ("null","mynull")
SetValue oCube = GetPrim ("cube","thecube","mynull")
What am I missing why I keep getting a semi-colon error, I must have placed a semi-colon in every place possible,yet the error continues ?
Ahmidou
Re: Semi-colon Error
Post by Ahmidou » 29 May 2013, 06:40
Post by Daniel Brassard » 29 May 2013, 12:03
In JScript, you must terminate each lines with a semi-column, except the comment lines like so
//Jscript code
GetPrim ("null","mynull");
SetValue oCube = GetPrim ("cube","thecube","mynull");
Watch your variable declarations as well as per Ahmidou earlier e-mail as well i.e
var oNull = GetPrim("Null", "myNull" ....
Dan
Falam
Post by Falam » 29 May 2013, 13:46
It still fires a semi-colon error :( As I mentioned I put a semi-colon in so many areas in the code, the script won't work, so with that into consideration, if it's not the semi-colon, they it has to be the variable, there appears to be nothing wrong with the code, I'll look it over again.
Post by EricTRocks » 29 May 2013, 14:35
Falam, post your updated code that is failing with the semi-colons you added please so that others can assist you better.
Moderator edit: real name replaced by alias as per Falam's request - HB
Eric Thivierge
face
Post by face » 29 May 2013, 18:33
I think you mean:
JS:
VBS:
GetPrim "null","mynull"
Set oCube = GetPrim ("cube","thecube","mynull")
SetValue() is a Softimage command, not a javascript command like set in VBS.
face
Falam
Post by Falam » 29 May 2013, 18:46
face wrote:I think you mean:
JS:
VBS:
face
Thank You, works :)
Falam
Loop Problem A
Post by Falam » 09 Jun 2013, 17:53
JScript
for (var p = 1; p<=3; p++){
oNull = GetPrim ("Null", "mynull0")
i = 3.4
oNull.size = 3.0
SetValue (oNull&&".kine.local.posy",2)
How come the last null in the loop is the only one that has a value of two units moved in Y, shouldn't the other have the same ? I know the nulls are not physically moved, although there translation should reflect (2) ?
Post by EricTRocks » 09 Jun 2013, 17:59
Your set value is outside the loop.
Eric Thivierge
Falam
Post by Falam » 09 Jun 2013, 18:06
EricTRocks wrote:Your set value is outside the loop.
Thanks !
