see png alpha
clankill3r
see png alpha
Post by clankill3r » 24 May 2013, 09:39
I use a png as texture, now how can i see the alpha of the png?
Now it's just grey and black.
gustavoeb
Skype: gustavoboehs
Re: see png alpha
Post by gustavoeb » 24 May 2013, 10:15
If you DONT want to use HQV double click your material node and under the "OpenGL" display tab select the "use alpha as mask option".
In the example below you see this working on a simple constant shader with a noIcon image, which has alpha...
Gustavo Eggert Boehs
clankill3r
Re: see png alpha
Post by clankill3r » 24 May 2013, 10:39
thanks! works like a champ!
clankill3r
Re: see png alpha
Post by clankill3r » 24 May 2013, 11:32
in the render it's black :(
Does anyone know how to render it out correct?
I use Arnold, but a solution for mental ray is aslo welcome.
gustavoeb
Skype: gustavoboehs
Re: see png alpha
Post by gustavoeb » 24 May 2013, 16:31
Arnold doesnt have a transparency from alpha checkbox like regular SI shaders. Therefore you should create a new image (you can plug it to the same texture node) and enably "Alpha to RGB" option, than use that for opacity...
clankill3r
Re: see png alpha
Post by clankill3r » 24 May 2013, 16:34
thanks
