Python 2.6 works fine in 2013 sp1 (I can use Species).
In 2014 (2.7) Species has errors. How is your 2014 Python working?
Python problems
Falam
Re: Python problems
Did you upgrade to Python 2.7 and update your environment path ?adrencg wrote:Python 2.6 works fine in 2013 sp1 (I can use Species).
Re: Python problems
"Internal" Python I presume... If so there are more problems - apparently with the necessary pywin32 - as is also described in this thread, where I got the advise to "fall back" on an "external" Python 2.6
The RCTools are affected as well. I never tried Species, but I assume this to be the same problem...
There should be a service pack in the works, one might hope... ;)
Re: Python problems
@adrencg:
Please email me or Chris and we can work to get you straightened out. It's working fine for us on 2014 in our internal build. Are you using Species 1.6.1?
