Array in Cluster
Re: Array in Cluster
Shouldn't you build the array first and then select in array?
Falam
How would it be re-written ?Bullit wrote:Shouldn't you build the array first and then select in array?
Ahmidou
you don't have to rewrite it, what you currently have is a set, not an array.
what you need is "build array from set"
Falam
I was hoping, once I built the Array from Set it would be good, yet I know something is missing.
Ahmidou
You can't get a polymesh form a cluster, instead you have to filter the attribute you're interested in with the cluster.isElement.
Falam
Thanks that worked, forgot I have to get the attribute for the objectAhmidou wrote:You can't get a polymesh form a cluster, instead you have to filter the attribute you're interested in with the cluster.isElement.
