Use this thread to post any bug+workaround combos you know about
A method to alleviate the bug's pain will count as a workaround, too!
Please try and make your posts somehow structured like bug: [...] / workaround: [...] .
Feel free to reply/add to posts but don't be offended when some info gets merged, I'll try to keep it 1 post/1 bug.
The bugs+workarounds thread
Re: The bugs+workarounds thread
RRay discovered that one!
- Bug: When the pass environment is rotated using MetaSL shaders, the rendered output is ok, but the HQV shaded one is flipped.
mode affected: HQV Rendering
Work around: Use the renderer output (Q region) to confirm the pass environment rotation
