Color Polygon Loops
Falam
Color Polygon Loops
Is there a way to color, polygon loops on a mesh during modelling, identical to what Silo has ?
SamHowell
Re: Color Polygon Loops
I think you can change the colour of edge clusters. I have no access to Soft so I can't be sure.
Falam
I change the color of the cluster, but the cluster color is not showing up in the viewport on the object ?Sets the display color of the cluster's components when the cluster is not selected. If a component belongs to more than one cluster, it uses the color of the last cluster created.
SamHowell
Go to the eyeball dropdown menu in the viewport and tick Unselected Clusters (except sample).
Falam
This option was toggled on, when the object is unselected you don't see the colored clusterSamHowell wrote:Go to the eyeball dropdown menu in the viewport and tick Unselected Clusters (except sample).
It all depends on what you want to achieve exactly, but I wouldn't use "cluster materials" for this. Don't get me wrong, I'd still use clusters as such, as they are a good way to organize the data without breaking the normal workflow, but I think it's best to use the material nodes of the ICE Topology toolset to do the actual coloring/highlighting of the polygons, like I did in my TopoColors plugin (shameless plug of a shameless plug), mainly because they do not "interfere" with the "normal" material: you delete the ICE Tree and they're gone...
I'm thinking about constructing something along these lines (never a good sign)
SamHowell
Yeah, now I'm a bit confused. I thought you wanted to select edges and polygon loops to help as some kind of visual reference in the viewport. Is it actaully for rendering purposes? I think I misunderstood your question.
The method I described in my earlier post definitively isn't meant for rendering either... ;)
SamHowell
@Hirazi. I just checked out TopoColors, it's VERY cool and very usefull. I don't know how I missed that one, I really could have used it on a job not so long ago.
Falam
Color polygon loops wouldn't be for rendering, only for visual aid in the viewport, I can't claim it as my idea (although I'd like to, put another one in the bag of Falams Idea
) It is something I saw that Silo has within the software.
