I need to have different particle scales in different parts of same point cloud.
I tried to filter different parts of point cloud with objects w/ Test Inside Geometry but it seems it does not work, only the last Set Particle Scale node in Icetree seems to be working, seems i can not put more than one. Any idea of an alternative?
Build Array with that output? but then when i try to input in set particle scale it gives me a context issue.
Different Particle Scales in same ICE tree or PointCloud
Tekano
Re: Different Particle Scales in same ICE tree or PointCloud
simple. I think perhaps you are overcomplicating things in your logic.
also there is particle scale & particle size
show us your tree and we can see what is wrong? or just use the way I show below it is elementary dear Bullit
Many thanks, you are correct, i had a 3d vector input (that inputs animation in particle scale)>If Node> Set Particle Scale. Your solution is 3d vector > Set Particle Scale> if Node and it works. I think it is because the execute input in IF node leaves the False with nothing, while the 3d vector input in If node leaves the false with a value. I ended up chaining them and for some reason it worked but your solution is much more correct and tidy.
