softimage slow
ibra
- Skype: hendeweh
softimage slow
it is taking softimage about 10 minutes to open the dialog box for open/save file... the software is working fine, just very very slow.
need help please
need help please
mattf06
Re: softimage slow
hi,
which SI version? on which Windows?
Is it just SI or other app also? May be you have some unreachable network drives? In this case, disconnect its.
regards,
Matt
regards,
Matt
ibra
- Skype: hendeweh
Re: softimage slow
Win 7 SI 2014
Can you guide me through?
gustavoeb
- Skype: gustavoboehs
Re: softimage slow
Do you have any plugin workgroup set to a network address?
Gustavo Eggert Boehs
ibra
- Skype: hendeweh
Re: softimage slow
how do i check that?
i have gear and arnold
mattf06
Re: softimage slow
about network drives, easy:
start a Command Prompt
then, 'net use'
'net use' command display all network drives...
then, 'net use'
gustavoeb
Re: softimage slow
Use the plugin manager and under workgroups check the paths to which you r connected.
ibra
- Skype: hendeweh
Re: softimage slow
hey mattf06! i typed net use
it said:" New connections will be remembered.
There are no entries in the list."
yo gustavoeb! for the workgroups, i went to the plugin manager and then connected to my hard disk coz the list was empty...
nothing changed
nothing changed
ibra
- Skype: hendeweh
Re: softimage slow
actually, i closed and reopened XSI and the workgroups i linked to disappeared. the list is empty again
gustavoeb
Re: softimage slow
Well I guess that is not the reason for the slowdowns then. It was the only thing I coyld think of, sorry.
ibra
- Skype: hendeweh
Re: softimage slow
Re: softimage slow
before you do, I suggest you search on xsi support, there are many tips on the blog about slow start up and some ways to diagnose the problem.
http://xsisupport.com/2011/09/21/softim ... tup-times/
Dan
Dan
ibra
- Skype: hendeweh
Re: softimage slow
the software is working fine... its just when i open or save a file, xsi needs 10 to 20 minutes to do that which is very abnormal and unproductive....
ibra
- Skype: hendeweh
Re: softimage slow
before, it used to ask me if i wanna resume xsi in standalone mode or in network mode.
now it doesnt...
strange
now it doesnt...
strange
ibra
- Skype: hendeweh
[SOLVED] softimage slow
guys i finally fixed it, my cousin suggested i delete the user and make a new one and it worked! lol!
mattf06
Re: softimage slow
well... basic test:
start notepad
go to open a file
did you get the same behavior with notepad open file dialog box?
If yes, that's not a SI problem, but a Windows problem. Maybe explorer plugins?
start notepad
go to open a file
