Hi;
I have a simple twist op applied to a piece of geometry in my scene, the profile f-curve of which I'd like to reference to and control by another f-curve in a separate ppg. How do I go about accomplishing that?
Thanx in advance for all the help.
Cheers;
AJ
How to reference an operator's built-in fcurve
jacobo
Re: How to reference an operator's built-in fcurve
Oh oh... C'mon, no one?... Is it impossible to do? i couldn't find anything in the Sdk docs on this, so at least a pointer would do great.
I don't fully understand what you want, but this is how I get move proportional fcurve
CStatus getPropFcurve(FCurve &out_fc) //get move proportional fcurve
CSIObjectRefArray objArray = Application().FindObjects( siOperatorID );
Operator movprop;
for ( LONG i=0; i<objArray.GetCount(); i++ )
Operator op(objArray[i]);
if (op.GetName() == "MoveProportional")
movprop = op;
break;
if(movprop.GetName() != "MoveProportional")
return CStatus::Fail;
CParameterRefArray par = movprop.GetParameters();
out_fc = par.GetValue(L"profile");
return CStatus::OK;
jacobo
Thanx so much for the reply origin. What I want to be able to do is simply control the twist profile fcurve of the twistop via a proxy fcurve in a custom ppg, exactly like you would writing an expression on a param to have it controlled by another. Unfortunately for me, your example is in C++, and I don't know anything in that department
I've searched the SDK docs, but just couldn't find anything related to this. I'm really stuck...
// Select twistop and run script
var prop = ActiveSceneRoot.AddProperty( "CustomProperty",false, "MyCustomParam") ;
var proxypar = Selection(0).Parameters("profile");
var par = prop.AddProxyParameter( proxypar, "proxy_crv", "proxycurve");
prop.PPGLayout.AddFCurve( "proxy_crv" );
InspectObj( prop ) ;
