Hi all,
I'm trying Vray for softimage, and I'm using a dome light with HDRI. want to rotate my HDRI env in order to change my shadows orientation, but the rotation value in the vray envImage isn't taken into account.... Impossible to rotate directly the light too. What's the procedure to rotate my HDRI ? That's a bug isn't it ?
Thanks for the info.
Vray envImage : rotation
julius
azurecgi
Re: Vray envImage : rotation
Sounds like it could be a bug!
Have you reported this in the Chaos Group forum?
julius
I'haven't yet since I'm not used to Vray and wasn't sure that was a bug.
azurecgi
I have a full version of Vray for SI.
Let me run a quick test and if it does look like a bug, I'll post it up in the relevant forum!
azurecgi
OK!
I've tested it, and it seems to be working here.
How exactly are you applying the environment image to the dome light?
azurecgi
Here is my setup;
julius
ok sorry, it's working too. I have two dome lights, and one of them does not affect the diffuse in the options panel, so I was tweaking the wrong one.... Shame on me !
